RCU Forums - View Single Post - Online manual
Old 01-17-2009 | 06:45 PM
curtwithac
Default RE: Online manual
Your right it’s a relatively easy ARF to assemble, if you have assembled a single center aileron servo before. The problem I’m having is trying to figure where 1 part goes (a single piece of hardwood wave shape and is covered) and should there be a build up for the servo mount or do you glue the wings together around the servo using the wing as your servo mount, which means you can’t ever remove the servo once the wings are glued, because of the notch you have to make for the servo lead at the bottom of the wing. The instructions I received were for an Explorer 60 that shows a 2 servo aileron setup 1 on each wing. Any ideas?
Curtwithac
