use programmer or matchboxes?
I'm in the process of setting up a 40% extra and would like some input.A friend of mine also was setting up the same plane and burned up 6 5925's using the programmer.I'm convinced he did something wrong.I would rather spend the money on the programmer then on 2 matchboxes and be able to use it over and over again and not have to keep buying matchboxes.My question is,on a 2 rx setup ,running 3 servos in each wing,2 on each elevator and 2 on the rudder,how does one go about using the programmer on these.What is the proper setup as far as Y-ing them together,or seperate ports and slaved together.I think my friend tryed the latter of the setups and burned them up.He now swears by matchboxes,but I hold out hope the programmer is the best way to go.
