RCU Forums - View Single Post - Brushless Reverse???
Old 01-18-2009 | 12:46 AM
ozzymoose
Default Brushless Reverse???
I have an F-27 C Stryker and i wanted to put that motor in the F4U Course Air (parksone). On the stryker the motor is mounted in the rear and it pushes the plane. The Course air has a motor mounted in the front and technically pulles the plane. so when i mount the stryker (push) motor on the cousre air (pull) i need the prop to spin the opposite direction
