RE: 1/5 Sig Cub Build Pictures
Have been plugging away on the Cub build and got the roundels done on both wings now. I also started on mounting the aileron servos. I did not want to use the traditional "Wood Block" method to mount the servos onto the aileron hatches so I copied a design I found on the internet at Sierra. Purchased the aluminum angle at Home Depot for about $5.00 and have enough to make about 10-15 mounts. Ran out of bolts so the servo is not totally attached.
If you make your own be careful that the mount is not too wide and interferes with the mounting rails in the wing. I had to adjust the brackets to fit by making them a little more narrow.
Here are the results:
SunDevilPilot
