ORIGINAL: ozzymoose
well im pretty sure they're both outrunners its just that the stryker has a 1880kv motor and the Course air has like a 980kv motor...
Nope, Stryker is definitely an inrunner. Notice how the mount wraps around the outside of the motor? that wouldn't be possible with an outrunner. You can also see it here:
http://parkzone.com/Products/Default...ProdID=PKZ4216
I'm sure you could devise a way to mount it on the Corsair but you'd probably need to use some sort of gear reduction so it will turn a suitable prop.
I'd go with the E-flite 480 or something like the one I linked to earlier. It is almost a drop in installation using the stock mount. There's a guy on eBay I believe who sells aluminum mounts for putting the E-flite motor on the Corsair and T-28 so that makes things even easier. Also, the Parkzone batteries will begin to show their limitations with the more powerful motor. A nice 20C, 2200mAh battery makes a lot of difference.
