RE: Bud Nolsen Mr Mulligan
Well I found a little more time to work on the Mulligan. I layed out the right wing spars and ribs. Stacked up all the ribs with cabin side and drilled a 3/4 inch hole where the center 3/8 inch dowel pin was to be. As you can see in the pics, I doubled rib 4,5, and 6 with light ply since 1,2, and 3 are ply. This should stiffen the ribs for the 3/4 inch tube I will install for the wing jointer. I also installed a small 3/4 inch guide tube I made from thin plastic to help guide the tube in on assymbly at the feild. { Some day}. If you look at the pic for the alerons you can see I cut the last rib in line with the 1rst rib of aleron. I am going to lengthen the size of the aleron as mentioned before.
