Perhaps I was not clear enough on the relation between voltage and power.
The power available to turn the starter depends on the voltage available.
When you double the voltage, in effect you get 4 times the power. (It's actually a little short of that, because with the higher voltage, you also have higher losses due to higher current.)
But if you ever plan on running bigger engines, more power (grunt, grunt, grunt).
