ORIGINAL: buck1856
Ill have to see if i have one made up or have to make one.Do you plan on using the center out of the flywheel or do you need one made up for that.
Or are you going over the whole shaft?
I really don't know. I won't need the flywheel. I do like the looks of the type that cover the whole crank end. Does that answer your question?
Thanks, MikeB
