RCU Forums - View Single Post - northstar
Thread: northstar
Old 01-18-2009 | 11:08 PM
PeterC
Default RE: northstar
Instead of bracing the nyrod inside the nacell I run a piece of solid 2-56 rod from the control horn down to where the outer nyrod exits the fin inside the nacell. You can then pull the elevator pushrod out if you ever need to service the fuel tank.
Peter
