RE: NEUTRINO - NEW F3A PROJECT FROM GREECE
The variable stab position system cosists of four main parts ,the stab tube (carbon 12mm)can be set in any concievable position with a total travel of 30mm.The big irregular shaped parts are made of alluminum 1mm joined in the main fuse body.The filleted square parts are made of 3mm plywood with a 3mm blind nut in each corner and are held with 4 -3mm screws. theese can be set in any disirable position.
