The best tool to use is a stepped prop reamer:
http://www3.towerhobbies.com/cgi-bin...&I=LXK248&P=ML
You can use a drill bit but you have to be very careful since you can end up making the hole crooked or off center. If I were to use a drill bit, I'd to it on a drill press rather than with a hand drill.
