what tach are you using?
I have an older Glo Bee tach and it leaves a lot to be desired. It seems to jump around a lot and the readings vary depending on the angle the tach is held relative to the prop disc. I have heard that the TNC tach is really accurate but expensive. Is there a tach that will hold an accurate reading or is TNC the only way to go? Does anyone know where to get a TNC tach?
