RE: glue
Thanks Choppermike and iiiat, That was a lot of great info, you are right the wings can be glued by any model adhesive, It's the fuselage that takes the abuse, I will use epoxy up front.
I also thin 30 minute epoxy with alcohol after the hardener has been incorporated and use that thin mixture for fuel proofing balsa.
Work's Great!...Thanks again fellows
