RCU Forums - View Single Post - Still leaking fuel
Old 01-19-2009 | 10:18 PM
fly boy2's Avatar
fly boy2
Default RE: Still leaking fuel
ORIGINAL: Crash Campbell
ORIGINAL: w8ye
loose cap?
or maybe a split seam or pin hole in the tank that only appears under pressure? Did you submerge the tank in water, pressurise with a bicycle pump and check for a stream of minute air bubbles?
Cheers,
Colin
no but I'll try that; the way I checked for leaks first time was to fill with water and look for leaks
