ORIGINAL: LuftwaffeOberst
use Ultra on the Mono. You can't use Mono on Ultra because of the difference of the heat sensitivity of the Ultra.
Not true, I've done it both ways.
In fact, applying MK trim over UC is my preferred methid because you can use Trim Solvent and avoid using ANY heat
