RCU Forums - View Single Post - Prop wont fit
Old 01-20-2009 | 11:41 AM
bruce88123
Default RE: Prop wont fit
A tapered reamer will only give you a small contact patch at the correct diameter. The rest will either be too big or too small. Ditch the taper ream as far as props go. There are other places it can be used though. Best is for gradually enlarging holes in thin material, metal or plastics where a taper won't matter.
