RE: Flex Shaft Problems : CEN Aquajet
Its letting go on the Propshaft side of things.. Its the actual flex bit that comes undone.. not the actual connectors.. So both Connectors are secured solid but the Flex section on the propshaft connector pops out...
I am going to try the filed solder solution with some Locktite and see....
I am suspecting that the grub screw is vibrating a little and letting go even though its done up tight...
