RCU Forums - View Single Post - Official HPI MT2 Thread
Old 01-20-2009 | 11:51 PM
  #18714
SAVAGEBANE's Avatar
SAVAGEBANE
Default RE: Official HPI MT2 Thread
ORIGINAL: KeithjV
Matt it will take the small hump pack. Thats what I use in mine. You definitely want 6V though. Ill find you a link in a minute.
Savage more then likely the clutch spring is broken which like you said it causing the CB to engage as soon as the engine starts. Take the CB off and see what it looks like and get back to us
ok, i pulled the clutch bell off of the motor and found that the shoes are very worn but the springs are intact. interestingly when i pull the spring loaded shoes away from the shaft, one shoe seems to have more tension than the other. i am just going to replace the shoes and springs(any suggestions/links). Also i noticed that the truck had 15/52 gearing, i dont think that is correct even though it fits. the mesh is tighter than usual and when i roll the truck on the ground,the drivetrain is fully engaged all the time with the motor off.
any more suggestions ?????
