RCU Forums - View Single Post - Cool subject!
Old 01-21-2009 | 07:36 PM
lownslo's Avatar
lownslo
Default RE: Cool subject!
Thank you fellas for your replies!![8D] I went back and edited this because I forgot to ask: My boat is a Sea Queen with a stock motor that comes in the kit. They say it is a 3000 rpm motor, 12 volts, 3 blade 50 mm prop. I doubt if speed will be real good with this set up but right now I am "maxed out" on spending. I may change power later.
Will I need a pump for the water cooing, OR will the pickup in the prop wash be enough for cooling?
lownslo.
