RCU Forums - View Single Post - whats it called?
Old 01-21-2009 | 11:21 PM
SAVAGEJIM's Avatar
SAVAGEJIM
Default RE: whats it called?
ORIGINAL: motox28
what is the gear that meets with the spurr gear on ur motor called? the one by the clutch i stripped it out on my tnx and i cant find where to get it?
Yes, pinion gear is correct. If it is integral to the CB, as Mike said, CB gear is correct too.
To be certain, look at your owner's manual to find the PN and do a search on the net using the PN. You will find the exact same gear you are looking for.
