RCU Forums - View Single Post - F-16 and one more time CG recommendations
Old 01-22-2009 | 08:52 AM
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: F-16 and one more time CG recommendations
Michel:
Where did your old F-16 have the turbine installed? In the center or in the tail?
Mine had the turbine in the center and had all the bad behavior described by that Craig until due to this behavior it crashed.
I am planning to set the CG of my new F-16 in 175 mm as he reccomends.
According to Craig's experience, it seems that those F-16 with the turbine in the tail, are not affected by the CG set at 135 -145 mm, but those F-16 with the turbine in the center, has the bad tendencies described by him. Sounds crazy but it is my conclusion after reading another thread regarding this issue.
Please confirm where was your turbine installed (in the tail or in the center)
