RCU Forums - View Single Post - F-16 and one more time CG recommendations
Old 01-22-2009 | 09:14 AM
jetnuno
Default RE: F-16 and one more time CG recommendations
Hi
I am building a SM F16 and don't understand why there is a difference between these 2 kinds of install. After all a CG is a CG, whether you have a turbine mounted in the tail or center mounted. I believe Michel had a Super Bee installed in the tail and I already had a FEJ 1/8 F16 with a P60 in the tail. I used to had a CG of 140 and in the turns it used to pull down and flair was kind of hard, so I took of some lead from the nose until it flew great. I guess I should have end with 150-155mm
I am planning to build mine with a CG of 150mm this time to start with.
Good luck
Nuno
