RE: Exceed RC F-4E Phantom Newbi Question
Typerpaul5 Shame on you, but I know how it is to want something so badly that you go against odds. Go to Youtube.com and in the search area type in Exceed RC F-4 EDF and there are several reviews on this aircraft, the one by Dave Herbert is the best review hopefully this helps you out. Also on ********.com there is a review of this F-4 Phantom. If your charger is like the one that came with my F-35 then you should have a wire with alligator clips on one end and a bannana plug on the other. plug in bannana plug to charger and then the alligator clips to a 12volt car battery, then hook the end of the lipo battery into the charger. Best of luck (you'll need it) just kiddin, i truly hope your succesful in you conquest
