RCU Forums - View Single Post - shear webs
Thread: shear webs
Old 01-22-2009 | 04:03 PM
  #36
Campgems
Default RE: shear webs
You started a productive thread.
Your table is OK. To get it exact, you would need a huge granate surface plate.
The fact that the upper and lower spars don't line up and are tilted with relation to each other is probably why Sig designed as they did. It would be very dificult to use true shear webs with them as they would have very little contact with the sides of the spars, and if you bend them to fit, they would have to be S shapped. The compromise was to sort of fit the beam center in the center of the spars. When I used this method on my last wing which was a full symetrical airfoil, I lapped the beam center up on the sides of the spars, not like Sig did, but more like the more examples shown. One other thing, I don't use CA here as it has almost no gap filling ability and even then it is very brittle. I use Titebond carpenters glue. It dries out and leaves a nice fillet on both sides of the joint. It is also quite tough. I do thin it by adding about 10% watter to get better penetration of the wood.
Your best strength would come with the webs grain vertial. On my wing I was just talking about, I though about adding a 1/16 x 1/4 strip across grain on each side of a rib and one more in the center. My rib spacing is very wide, around 5" on a 60" wing. I didn't do it and I've yet to fly the new wing, so I'm hopping my decession was right.
Don
ORIGINAL: kargo
wow did I start some flaim bait There is more than one right way to do something and everything has its pro's and con's. I appreciate all the advice. I think I need work on my technique for making the shear webbing true enough to not have gaps. A trip to menards for some tools, either parts to make or store bought.
So far as the building board flattness goes I did check it with a long metal ruller on edge. There was a gap in the middle of the ruler that a micrometer would have difficulty measuring. Just enough to let the table length ruler move across the builing board a little more easily than at the outside edges where the ruler was firmly touching the board. I don't know if this is too much or not. I build on homasote (avail menards, etc) which is afixed to 3/4 ply by double sided tape (sig recomendation in their instruction books. I have too old office desks, one wood one metal that are about as flat as you could hope for, one wood table thats not (bows in the middle, I use the ply to make it straight), and the a makeshift table out of hip height shelves (also with the 3/4 ply setup). It seems like all the homasote buiding boards have that imperseptable "sag" in the middle. Not perfectly flat but very close to it. Without building on metal with magnets or on glass, I don't know how I'd get any flatter. That said I'm open to suggestions[8D].
The shearing explenation was great. Can I make this work when the spars are not perfectly parallel to oneanother? The top spar follows the counture of the rib so it is at a slight angle compared to the bottom spar. Does it matter if the shear webbing has a slight bow to it? How about grain direction? Again, I probably just need some more practice, but I am a "keep it simple" kinda guy. Thanks again. Is info on shear webs like this in the beginers forum? It might help some other folks too.
