RE: AMR 33% Waco YMF-5 Build
Lonnie
Hi
Take a look at the enclosed pictures. Look real close. Really study the trailing edge one were the ailerons are attached. Look were the taper starts. Like between the 3 and 4th rib.
Also look were the Spars are and the leading edge is.
I have been told that the pica section is real close. There is a problem with were the spars are but the outline is dead on.
Take a look at the difference of the AmR leading edge template and the Pica.
Pay close attention to where the last rib is. It is shorter the the others. It is part of the taper
I am working on more and will cover this more with drawing.
TR
PS Most of these pictures came from John Howard and I am sure at some point he will come in with his wisdom.
