RCU Forums - View Single Post - U-Can-Do 3D -- No Luck So Far!!!
Old 06-07-2003 | 02:27 PM
jsnipes
Default U-Can-Do 3D -- No Luck So Far!!!
Do yourself a favor and get either a Cline or Perry. I got a Cline and have had zero problems. Idles so low and reliable that you can almost count the rpm's. No burbles in a hover. It's great! It's 60 dollars (which seems to be a rip off), but money well spent when you get the results.
Steve ... all you have to do is put on a remote glow to solve the glow plug position problem ... that way you don't have a big honkin' cylinder sticking out the side of the cowl. The one I bought was around 7 dollars and mounts on a little angle bracket. A small hole in the cowl provides access.
JS
