RE: engine break-in and needle settings
yes it means 3.75 turns out from bottom. You turn the needle all the way in and then back it out. 3.75 is the same 3-3/4 turns out. Do what the manual says and break it in. Yes it is rich but that is the way they all are out of the box. After you break them in you can lean them out.
