RE: 2000mah Battery
sjgusmc21, just be careful when putting your batteries on the charger several times, monitor both the charger and the batteries closely. If either gets hot stop imediately. You probably know this, but I thought it was worth saying. If your battery is going bad, you may damage the battery or the charger trying to "stuff" the entire 2000mah into the battery.
