RCU Forums - View Single Post - Exceed RC F-4E Phantom Newbi Question
Old 01-23-2009 | 04:56 PM
million-air
Default RE: Exceed RC F-4E Phantom Newbi Question
To be frank with you, im not going to be one of those people that will blow sunshine up your... Take it from the old man (pretty seasoned rc pilot) that bought that exact plane as his first edf because it looked sweet and cost is pretty low. You know that warm fuzzy feeling you get when you have a new airplane? well it went away as I watched my plane kit istelf all over again. It snapped probably only due to excessive elevator because I was going at reasonable speed. Although it was pretty tricky to fly with the nitroplanes TX that came with no springs that centers the stick that controls the elevator (like the throttle stick, although im not using that as an excuse). Try going with something else that can fly slow and easier to see. A good plane would be the eurofighter typhoon, or the stealth fighter because of the maximum amount of wing surface. Anyways just trying to help your cause and good luck with your edf flying.
g-day
Ayrton
