RE: SKYMASTER VIPERJET ASSEMBLE THREAD
Not sure if the photos I saw were either prototype locations or intended, but I saw the elevator servos mounted in the root of the stab on the fuse side. Which seemed like that would work fine, you just have to disconnect the pushrod to the elevator if you take the stabs off. I think the same applied to the vertical. Either way would be fine.
Billy
