RE: Cap232 .60 setup for control surfaces etc
Caps are nice flying aircraft. Don't have one right now but enjoyed in past. Gerally set up throws form manual butwhen don't have one use what I have been used to in past about 3/4" . If you have dual rates set high rate for that and reduce low rate to maybe 1/2". That way will give you something safe to judge by. Caps are very responsive so if you lack experience have someone check it out for you. Good luck.
