RCU Forums - View Single Post - Two fans that will not synchronize
Old 01-24-2009 | 01:26 PM
cyclops2's Avatar
cyclops2
Default RE: Two fans that will not synchronize
If you have the 5v/3a version you are PROBABLY good. Make very sure all the servos linkages, can rotate freely into all the stops in the servo. If they can not and you do a long stick command at the end of travel, it will overload the switching BEC and shut down till it cools off enough. I noticed where they stated the throttle trim was available. Send them a E-Mail about yours not holding your adjustment after programming it with a PG card.
You are now a qualified multi engine builder.
