ORIGINAL: show871
Hey, I had just a few questions on this plane
Do you have long term problems with the black covering in the sun.......after the initial few bubbles are taken care of
Does the new kits come with tinted canopies?
Is the SD 33% gear the correct CF gear to use....and how much weight do you save?
Has anyone used the MT 57 on this plane?
Hey thanks!
871
the black does wrinkle more than the yellow here in az, i wouldnt call it a "problem" though...
the 33%sd is the gear to use if you want the cf, i heard its half the weight of the stock ef gear, for some reason 7oz's sticks in my head and the stock stuff was 15oz's, i dont remember if thats accurate but it seems to be sticking in my head for some reason, but im getting older so i could be way off
