RE: RCGF Engines
Yes you are correct I used vertical center of 49mm and horizonal of 68mm but to put the prop in the center had to use 19mm and 30 mm and it worked out perfectly. On the templet on the web it showed 24.5mm up and down this should be changed to 30mm and above it should be show 19mm for a total of 49mm. then the prop would be on center line.
