RCU Forums - View Single Post - Having trouble getting started, help please?
Old 01-25-2009 | 01:18 PM
Chris_RC's Avatar
Chris_RC
Default RE: Having trouble getting started, help please?
lean the lsn a little bit. or idle needle. What you should do is Hold the exhaust nipple with your finger and pull the pull start a couple times till it JUSt reaches the carb. the second it reaches the carb, stop priming. Get a fully charged glow igniter and you should be good. if it still doesnt start heat the head with a hair dryer and try to get it as hot as you can.
