LV setting on esc?
I have an elfite and a motrofly esc. Both never hit the cutoff point even when its set to the highest level. On my Yardbird F22 I run a 1300 3S 25C batt,1700KV motrofly. I get about 6mins and leave the batt to around 11.3v. Is that level too high for the cutoff to work? Im end up putting about 80% back into the batt. If my voltage is still that high can I run it down lower w/o damage to the batt? If the pack is a 1300 and I end up putting say 1300mah back in will that harm it? What should you go buy voltage or mah?
