http://www.hobbycity.com/hobbycity/s...hless_Inrunner
run this motor, the other is max 45 amps, and will dier a horrible death trying to push your savage. also, id advise against that esc, they refer to them as the beeping nightmare, as the instructions are never accurate and setup is virtually impossible unless you can find a programming card, which there are a few on that site for cheap. this motor will run hard on your 3s, so wire for max amps (cuz that motor will pull them)
