RCU Forums - View Single Post - Co-Pilot
Thread: Co-Pilot
Old 05-30-2002 | 08:50 PM
jmgans
Default Co-Pilot
Plane totalled!
When attempting to install on another plane it became obvious that the roll sensor was bad. Even in the setup mode as soon as in the roll position the ailerons just went crazy-even occured with the remote power switch in off postion.
FMA says they have had a few bad sensors, and now have the unit for repair. I 'm not sure if I will reinstall, however. It sure does work as advertised and will tame even the wildest plane, but if it glitches, there is nothing you can do. The more complex we build them, the more there is to break!!
