RCU Forums - View Single Post - CNC HEAD INSTALLATION
Old 01-26-2009 | 10:11 PM
cjennjr
Default RE: CNC HEAD INSTALLATION
I finally figured the build sequence out - although I need another inner rod due to bending it trying to get it out, I got the CNC head assembled and on my Raptor. Another thing I've found out about the CNC head - if you tighten it like it should, the whole head binds (no real freedom of movement). I have to loosen the bolts a little in order for the head to move effortlessly. It should not be like this; I'll probably get some thread lock and put a drop on the screws. I hope the thread lock don't lock the head completely. I must say the looks are astounding - just need to do a test run after I get the inner rod. Will keep everyone posted on the results.
Oh, another thing - the swashplate ball links DO NOT fit the steering holder!!!! What gives???[:@] I guess I need to order a set of aluminum balls and see if they fit!
