I don't think you need to change the exhaust port timing for pattern use. You will need to change the size of the intake ports which is vert risky proposal. Check this web site for recommended set up and you will be fine. I use this engine for two or three years in pattern with no problem. Very reliable engine.
http://www.rcpattern.com/2cycle.htm
