RCU Forums - View Single Post - Servos don't move
Old 01-27-2009 | 02:23 PM
RICKSTUBBZ's Avatar
RICKSTUBBZ
Default RE: Servos don't move
ORIGINAL: RCKen
ORIGINAL: RICKSTUBBZ
Lokidog,
What I can tell you is the wiring is different between Futaba and Airtronics.
Rickstubbz,
Not on the RDS 8000. Airtronics uses the same servo wiring pinouts as everybody else now, and has for at least the last 5 years or so. Yes, older Airtronics radios had the polarity reversed on them. But now they are the same as the Futaba servos he is used.
Lokidog,
Have you tried re-binding the receiver to the transmitter?? Give that a try first and see if they will work after that.
Ken
Ken, Lokidog,
This is obviously one of those occasions were I should have kept my mouth (fingers still) shut. Thanks for the correction Ken, Good luck with your problem Lokidog...
