RCU Forums - View Single Post - More right thrust needed?
Old 01-27-2009 | 06:25 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: More right thrust needed?
ORIGINAL: beachbrada
also when I add right thrust to the engine the nose should point a little more towards the left, is that correct?
I beleve you have that backwards. When you have right thrust the crankshaft of the engine will be pointing toward the right when looking at the airplane from above and the rear.
