RE: Servo Driver/Tester
Hi where do you start. Just learning about r/c planes but have been building models for a few years. Don't know what setting to use, for exp Throttle adjust how to set. Do you center or zero servo when you install in plane. When you center the travel ADJ would be different then when you zero or does it mater? I know that you need to center the ELEV, RUDD and Gear. Would like to keep as close to center as posiable and to help with building time. My time is limited I worked out of town 316 day's last year. Just thinking this will inprove building time.
