RCU Forums - View Single Post - need help with e maxx problem
Old 01-27-2009 | 07:26 PM
camaross427
Default need help with e maxx problem
So i have been having problems getting the gearing on my e maxx to be right, for some reason now the car won't move, i thought it was a problem with the spur gear or slipper clutch so i bought new slipper clutch pads and a new spur gear..well i am still having the same problem...it's hard to explain so i took some vid's..sorry not the best vid's but i think they help
in this video i have only one motor's pinion gear meshing with the spur, the other is not contacting it, as you can see the car does move with the spur gear and pinion gear's on the motor...although not very smoothly..
[link=http://s47.photobucket.com/albums/f154/camaross427/?action=view&current=P1050105.flv"]http://s47.photobucket.com/albums/f154/camaross427/?action=view&current=P1050105.flv]link[/link]
now in this second video both motor's pinion gears are meshed with the spur gear. As you can see the car does move but none of the gears move. just the shaft and the lock nut at the end of it..
[link=http://s47.photobucket.com/albums/f154/camaross427/?action=view&current=P1050106-1.flv"]http://s47.photobucket.com/albums/f154/camaross427/?action=view&current=P1050106-1.flv]link[/link]
so what is going wrong? i took it apart and reasambled may times but can't figure it out..i will bring it to the shop to fix it but only as a last resort..thanks for your help!
