RCU Forums - View Single Post - Rudder Hinges Pulled Out!!
Old 06-07-2003 | 06:00 PM
David Cutler's Avatar
David Cutler
Default Rudder Hinges Pulled Out!!
Unless you are extremely lucky, CA glues, especially thin CA, don't tend to work twice.
Try it on a piece of wood. Soak the two surfaces with thin CA, let it set, and now try to glue them together.. It's not easy!
For the sake of the plane, re-do the hinges. I would suggest simply cutting them off, and using Robart hinge pins.
-David C.
