RCU Forums - View Single Post - MEGA ACn F3A
Thread: MEGA ACn F3A
Old 01-28-2009 | 04:35 AM
BBpattern
Default MEGA ACn F3A
Does anyone has experiences with or thoughts about this motor?
Type class
Brushless motor MEGA ACn F3A.
Diameter 44mm, Length 120mm, Weight 519g
Description
Special brushless motor for aerobatic airplanes category F3A with 10S Li-Po batteries. Recommended too for big airplanes up to 10kg and scale gliders up to 20kg, 8-12S Li-Po or 24-32 Ni-Cd (MH) batteries. Propellers up to 22ā€, current up to 60A.
Diameter: 44mm
Length: 120mm (without shaft)
Weight: 519g
Shaft diameter: 8mm (M
Efficiency: 88% (25-30A)
Resistance: 11mΩ
No load Rpm: 850 Rpm/1V
Gear ratio: 5:1
Rpm behind gearbox: 170 Rpm/1V
No load current: 1,4A (10V)
Recommended batteries: 8-12S Li-Po (24-38 Ni-Cd/MH)
Recommended prop: 18-22ā€œ (F3A APC-E 22x12ā€œ and 10S Li-Po)
Recommended controller: JES Advance 90 Acro (HV), TMM 9032-3
Application examples
ACn F3A
Photos
