RE: YS160 surging at Idle
I had a similarish problem with my YS160. It started fine but would only run with the needle >3 turns open, the needle was also very insensitive. I stripped and regasketed everything - the only thing I found was a tiny pin-hole in the silicon pipe from the crankcase up to the regulator. Runs fine again now.
