ORIGINAL: richardci
I was also within two feet with the antenae extended.
If you were this close to the plane then this is quite likely your problem. When a transmitter is this close to the receiver it can actually overpower the receiver and cause problems exactly like you are experiencing. Do a proper range check on the plane and see if the problem persists.
Ken
