RCU Forums - View Single Post - EDF Predator UCAV from Nitro Planes
Old 01-28-2009 | 05:25 PM
Kwesdog
Default RE: EDF Predator UCAV from Nitro Planes
I know where the CG issues are coming from now. I couldnt pass up this nice looking airplane for 130 bucks so I got one and have it 90% done.
The motor is no where near far enough back. To even get close to hitting the CG with where the motor sits even when its all the way back in the saddle you will have to put weight in the back or slide the batteries over the intakes on the airframe. I had to line up the back edge of my packs with the lip of the inlet and I was at about 7.25 inches back from the wing. That was with my 8S1P 3850 packs. I plan on going with an 8S2P 4000 but this is going to add another few ounces and I dont know how much farther back I can reall y push it before the packs get into the airflow. Not that it will matter a whole bunch as long as I am not restricting the airflow since I am not going to run inlet ducts but then its a pain to plug in the batteries.
Harry
