RCU Forums - View Single Post - Help! ailerons gone crazy!
Old 01-28-2009 | 05:57 PM
wzak29's Avatar
wzak29
Default RE: Help! ailerons gone crazy!
None of the proffessional cleaners work as well or as long I've had many recalles using them, working on military Eqp. I
had access to every cleaner, nothing lasted as long as WD-40, safe for all electronic components and drives out moisture. Also many spray cleaners
use a lot of pressure and dischard very cold this can damage electronics, the cold can also permanently change the oscillating frequency of crystals. (I don't know if WD-40 will damage wood) recommend remove electronics before use.
